2011 Chevy Cruze w/1.8l engine (Codepalooza)
- Richard6767
- Topic Author
- Thank you received: 4
Any suggestions on what part of book I should focus on for diagnostics so that I don’t throw more parts at it?
- Thank you received: 961
Is it installed in the correct orientation? It's hard to get it on there backwards or upside down, but it's worth checking.
The codes and symptoms are text book examples of a sticking purge solenoid, and it is a very common fault on this engine.
And this might sound like a dumb question, but did you clear the codes after you changed the solenoid?
I only ask because the way your post reads it seems like you changed the valve and checked codes but they were still present, which they will be until you clear them.
- Richard6767
- Topic Author
- Richard6767
- Topic Author
- ontheriver
- Thank you received: 16
- Richard6767
- Topic Author
- Richard6767
- Topic Author
P0496 is usually a slam dunk... With the engine idling, purge unplugged electrically and the vapor line (from the tank) off the purge valve, does a vacuum gauge show any vacuum?
- Richard6767
- Topic Author
That's what I was wondering about. You hit clear, but did the code actually clear? :huh: If it didn't, then I would suspect that it's being stored as a Permanent code, and you're chasing your tail.P0496 is gone but P0442 remains after clearing codes the 2nd time. First time there was a glitch or something.
If the P0442 is being stored as Permanent, you'll never be able to smash the 'Clear' button hard enough to make it go away. Permanent codes play by different rules. They won't clear until the EVAP monitor has run enough times to prove that the small leak is gone.
If the P0442 did in fact clear and returned after a test drive and a cold soak, then disregard the above and test away!
- Richard6767
- Topic Author
- Richard6767
- Topic Author
Start the Cruze, sometimes ABS light stays on. Other times it turns off, on this scenario at about 5mph ABS comes back on and at about 10-15 mph Service Stabilitrak and Service Traction Control System comes on. In looking up how to diagnose this problem, YouTube suggestions range from most absurd of change Coil Pack to test ABS Wheel Speed Sensor with multimeter but doesn’t tell me how to the tone ring on wheel bearing hub. My question is can that be done with something other than a scan tool. My scan tool is limited in that department as well. It doesn’t have live data on ABS. The ABS code my tool shows is C0050-5A, Right Rear Wheel Speed Sensor Circuit- Not Plausible.
I believe, these are magnetoresistive Wheel Speed sensors. The brake module will supply a power voltage on one wire and a ground on the other. Another way to find a bad section of wire is to use a volt meter, or scope to backprobe the connector, power and ground, so that you can read the voltage supplied by the brake module. Now, start wiggle testing the wiring harness while watching for voltage changes.
Graphing the wheel speed sensors while on a test drive, or rotating by hand, would be the easiest thing. This SMA video definitely applies:
- Richard6767
- Topic Author
- Richard6767
- Topic Author
- Richard6767
- Topic Author
- Richard6767
- Topic Author
- Richard6767
- Topic Author
- Richard6767
- Topic Author
In the right rear wheel well is another connector that I suspect could be the ABS harness considering it has multiple wires and a pigtail comes out of it going to the right rear wheel speed sensor. Haynes repair manual wiring diagram doesn’t appear to cover ABS wiring.
