- You are here:
Home
Forum
Main Forum
Post your repair questions here
- Dodge Nitro diesel
Dodge Nitro diesel
- ivoalaska
- mashili
- Topic Author
- mashili
- Topic Author
- mashili
- Topic Author
- shootingchimp
- Thank you received: 4
KOEO testing at injector plug may show a nominal low voltage, used by the pcm for circuit integrity testing.
- mashili
- Topic Author
- BreakerPoints
are those injectors Bosch with a fuel line from top? Any chance they are piezo injectors and not a solenoid?? How did you check for power and ground at the injectors? I guess you are aware that you shouldn't disconnect piezo during operation.
- mashili
- Topic Author
- BreakerPoints
I think you will need oscilloscope to test them, there is short pulse of voltage on them and it goes up to 200v, but basically you need a amp clamp probe to check them. Approximately amp draw is up to 10A. Dvom can not be used to pick up that fast pulse of a voltage. I am talking generally not about your specific car.
- mashili
- Topic Author
- BreakerPoints
There are pids and actuation tests on a bidirectional scanner which comes in handy.
- mashili
- Topic Author
- mashili
- Topic Author
Forum Access
- Not Allowed: to create new topic.
- Not Allowed: to reply.
- Not Allowed: to edit your message.
