× Help us help you. By posting the year, make, model and engine near the beginning of your help request, followed by the symptoms (no start, high idle, misfire etc.) Along with any prevalent Diagnostic Trouble Codes, aka DTCs, other forum members will be able to help you get to a solution more quickly and easily!
Re:Re:Re:2015 Armada No Heat
  • Tutti57
21 Nov 2020 18:08 #44520 by Tutti57
2015 Armada No Heat was created by Tutti57
Yes, another no heat complaint. Another tech says he had a hot line to the heat core and cold out so he back flushed it. I have hot line into the water valve near the fire wall before the heater core and maybe, maybe, a warm hose coming out.
I forgot that this is not just a solonoid that is opened or closed and thought I had no power at it from the AC auto amp, so I replaced that and when I didn't fix it I realized it's supposed to open and close from the AC auto amp based on temp knobs and only moves when the knobs are actually turned. It's got gears, not a solenoid. Both wires are grounded until the knob is turned then one side becomes a power depending on if it's opening or closing. Idiot, I knew this too. I took one apart like a year ago.
Knowing that, I have 10.5v on it when the temp knobs are turned. SI says it should be B+. I also have 10.5v coming out of the AC auto amp, so it's not high resistance between the two. Tested powers and grounds to the amp and all are good with near B+ in and 40mv on ground. My power probe makes the valve move with 12v.
Now, are the gears a little rough or something and my 12v blast is enough to move them but the "normal" 10.5v it's getting isn't, and maybe it would be enough for a new valve, or is my AC auto amp bad?
If you read my recent Pathfinder no heat post, you might understand why I'm questioning the new amp I put in it. My parts dept was also having a hard time determining the part number for some reason and had to contact Nissan about it, so I'm not exactly filled with confidence there.
I always struggle when numbers are like this because voltage drop is such a big concern. It seems ridiculous that it would be designed that way. It makes me want to just use a test light and focus less on the specific numbers, but I've definitely had cases where that would have burned me, so I don't know.
  • Letting the magic smoke out since 2011
21 Nov 2020 21:07 #44527 by Tyler
Replied by Tyler on topic 2015 Armada No Heat
I've never played with one of these water valves before, so bear with me. :silly: If I understand you right, this valve is actually motorized. I don't know that it'll change your diagnosis, necessarily, but it might be fun to take a current reading with an amp probe during valve opening. If anything, it might streamline diagnostics in the future. The current waveform would tell you if the motor is turning/locked/freewheeling/electrically open/whatever.
You could also compare the amount of current the motor draws with your Power Probe to what it draws with the AC auto amp? Just an idea.
I think your instinct to use some kind of substitute load is right on. There's no resistance spec for this thing, of course, so you'll have to use your best judgement on how big a load. Maybe one or two amps?
My money is on a bad water valve. B)
  • Tutti57
21 Nov 2020 21:34 #44529 by Tutti57
Replied by Tutti57 on topic Re:2015 Armada No Heat
Thanks! I think you're gonna be right about this. I'm a classic over-thinker, so these ones kill me.
22 Nov 2020 07:21 - 22 Nov 2020 07:51 #44534 by Monde
Replied by Monde on topic Re:2015 Armada No Heat
If I understand correctly, the A/C Auto Amp is the middle man. Based on knobs position, it provides 12 v to the control valve. You have 10.5 v going to the valve from the ac auto amp. So, the control valve does not get what it needs to perform its jobs. You applied 12 v to the valve and it moves. Do you now have heat? I believe you don't, but should, since you are doing the job of the ac amp.(Engine should be running when 12 v is applied to see if the control valve works or does not. If it does, you should get heat and moves towards the a/c auto amp and the knob)
If the motor windings were open, you would not hear anything when applying 12 v with the probe ( No path for current to flow). If the windings were shorted, a fuse would have blown somewhere and I don't think the valve would open with 12v applied. There might be high resistance in the windings. If the motor were locked, it would pull too much current and blow a fuse.
I know you will fix it in the end.
Never assume, diagnose!
Last edit: 22 Nov 2020 07:51 by Monde.
  • Tutti57
22 Nov 2020 08:51 #44535 by Tutti57
All correct, except for there is no fuse here. The valve goes directly to the amp. Right before I left yesterday I powered the valve with PP and let the truck idle while I cleaned up to see if I had heat flow through and I still didn't. I don't know how long that motor has to turn to open but I do think it's the valve.
With there being no fuse, what if it did internally short or the gears got jammed?
Since both wires are grounded normally, if I tried to provide power going from B+ to one side of the valve, my light would just light up, right? I don't think it would make the motor work.
22 Nov 2020 10:29 #44536 by Tyler
Replied by Tyler on topic Re:2015 Armada No Heat
Tutti57 wrote: Right before I left yesterday I powered the valve with PP and let the truck idle while I cleaned up to see if I had heat flow through and I still didn't. I don't know how long that motor has to turn to open but I do think it's the valve.
Does this look like the valve in question?
I was trying to get an idea of what kind of gear ratio it uses to turn the valve, but I can't really tell from pictures. :silly: Thought that might give us an idea of how long it takes to move the valve.
Speaking of, there's no position sensor in the valve, right? So I figure the AC auto amp has to be monitoring current on that driver circuit to make sure it doesn't strip the gears in the valve. Kinda like Chrysler/Dodge/Jeep HVAC actuators.
While I'm thinking out loud... Does the presence of the valve require special bleeding procedures? Or, can I just use my vacuum filler like normal?
  • Tutti57
22 Nov 2020 14:24 #44547 by Tutti57
Replied by Tutti57 on topic Re:Re:2015 Armada No Heat
Yep, that's the one. I have not bled one of these with my vacuum tool since I've gotten it, so I'm not sure, but I think I would do koeo with heat on 90* to make sure the valve is open. Using the coolant funnel set up can be tough with these. We will usually try to lift the front of the truck up while doing it. I got the vacuum tool for these dang things and haven't needed it yet cause we don't see a ton of them. Same set up on the titans.
I will likely be replacing the valve and I'll dismantle it to see what is in there exactly.
  • Tutti57
24 Nov 2020 12:08 #44624 by Tutti57
Well it was the valve. I'll take the old one apart in a bit.
24 Nov 2020 18:13 #44632 by Tyler
Replied by Tyler on topic Re:Re:2015 Armada No Heat
Fixed another one. B)
24 Nov 2020 18:13 #44633 by Monde
Replied by Monde on topic Re:Re:2015 Armada No Heat
i started to read about your issue yesterday at work, but did not have enough time.
One thing I remember seeing was someone use an infrared thermometer and checked the inlet hose to the valve and found that it was hot and the outlet cold.
Anyway, I am happy that you fixed it.
  • Tutti57
24 Nov 2020 20:51 #44635 by Tutti57
Replied by Tutti57 on topic Re:Re:Re:2015 Armada No Heat
Thanks fellas. This is a common issue on armadas and titans and yes I go right for those hoses. You can put your hand on then and feel that one is hot and one is cooler. The other tech claimed that he did this but I don't believe him since the valve wasn't working and he said that it got better after his heater core back flush but it was straight cold air when I got it.
Here are the guts if the valve.
How would you have gone about this if you found one side of the hose cold, then 10v at the connector? I feel like I would have questioned that 10v and not known if it was ok or not if I did this all over again.
25 Nov 2020 08:22 #44647 by Noah
Replied by Noah on topic Re:Re:Re:2015 Armada No Heat
So that doesn't function like the old Ford vacuum control valves that only shut off coolant flow for max A/C?
Good find, keep up the good work!
-Seems to me that I could live my life, a lot better than I think I am.
I guess that's why call me The Working Man.-
25 Nov 2020 11:29 #44650 by Tyler
Replied by Tyler on topic Re:Re:Re:2015 Armada No Heat
That looks like a goofy setup. :lol: No wonder those break all the time.
Maybe I'm way off? But I still think a current waveform would be useful on these, depending on the nature of the failure. I'm imagining a known good is something like a window motor. Steady current with the valve turning, then high draw when it reaches the stops.
Mail me this valve and I'll play with it. B)
  • Matt T
  • Away
25 Nov 2020 12:21 #44652 by Matt T
Replied by Matt T on topic Re:Re:Re:2015 Armada No Heat
Tyler wrote: Maybe I'm way off? But I still think a current waveform would be useful on these, depending on the nature of the failure. I'm imagining a known good is something like a window motor. Steady current with the valve turning, then high draw when it reaches the stops.
Sounds reasonable. You'll see the commutator segments if it's turning. And if the current doesn't go up the gears are likely stripped.
  • Not Allowed: to create new topic.
  • Not Allowed: to reply.
  • Not Allowed: to edit your message.
Time to create page: 0.362 seconds
