[FIXED] 2016 FORD EXPEDITION
4 years 3 weeks ago - 4 years 2 weeks ago #38888
by abe1204
[FIXED] 2016 FORD EXPEDITION was created by abe1204
here a fuse box a ford wont crank
Last edit: 4 years 2 weeks ago by Tyler.
4 years 3 weeks ago #38890
by abe1204
Replied by abe1204 on topic 2016 FORD EXPEDITION
from right top second relay
4 years 3 weeks ago #38892
by abe1204
09 relay
- John Curtis
- Thank you received: 109
4 years 3 weeks ago #38900
by John Curtis
Replied by John Curtis on topic 2016 FORD EXPEDITION
You need to see what you’re missing.
Check power on fuse 13 (30 amp)
At relay
Check pin 2 yellow wire is starter motor control during crank this should light a test light.
At pin 3 you should have B+
With key in run try jumping pin 3 to 5. This should power up your starter.
At the starter brown and green should like a test light or have B+.
Higher amp bulb (headlight bulb) test red wire at the starter and ground and see if it lights. (Checking off circuit can handle current)
Verify good grounds.
At relay
4 years 2 weeks ago #38902
by Cheryl
Replied by Cheryl on topic 2016 FORD EXPEDITION
Your not getting any trouble codes on a system scan? You have a health report? So we can have something to go off of. Do you see crank request information in the bcm?
4 years 2 weeks ago #38903
by abe1204
Thank you Cheryl the one that i get is the number 09 relay RUN/ CRANK RELAY this relay is not working properly I found out that this relay supply voltage to PCM and ABS . so i changed and it works and crank fine now ,,
4 years 2 weeks ago #38904
by abe1204
THANK YOU JHON, yesi do checked everythings and i found that relay number 09 is not working propely i changed a new one it cranks fine now RUN/CRANK RELAY ,,
- John Curtis
4 years 2 weeks ago #38908
by John Curtis
Glad your all fixed. Can you changed the threat title to add “fixed” I think you just edit your first post and change the title that way.
4 years 2 weeks ago #38937
Replied by Tyler on topic 2016 FORD EXPEDITION
Threw the [FIXED] on there.
The following user(s) said Thank You: juergen.scholl, abe1204
Time to create page: 0.232 seconds
