2002 MR2 Roadster. 1ZZ-FE, misfire and low idle when hot.
- kamiwolf0893
- Topic Author
- Thank you received: 2
4 years 3 weeks ago #38898
by kamiwolf0893
Replied by kamiwolf0893 on topic Re:2002 MR2 Roadster. 1ZZ-FE, misfire and low idle when hot.
Bias voltage would be used by narrowband o2 sensors right? .450 being stoich?
4 years 2 weeks ago #38909
by Dylan
Replied by Dylan on topic Re:2002 MR2 Roadster. 1ZZ-FE, misfire and low idle when hot.
Yes seems to me the heater circuits are dead. I really advise you to use OEM sensors. I've had Toyotas with bad O2'S and they're pretty sensitive when not using quality parts. I would've expected a DTC as well.
4 years 2 weeks ago #38910
by Dylan
Here are some videos for you.
Check out the playlist from chapters 4&5 on YouTube. Lots of good videos.
www.youtube.com/playlist?list=PLD2809EEC7BAAF989
- kamiwolf0893
- Topic Author
3 years 9 months ago #40999
by kamiwolf0893
Hi, I finally got around to testing fuel pressure and it turned out it was way above spec, I fitted a new regulator and used the previous injectors that were giving me a rich reading (these were new) which has brought fuel trims back to 0. I still have a misfire however which I'm trying to trace. I've since bought a Hantek 1008c, tested crankshaft and camshaft sensors today but I could do with some known good waveforms to compare to. Also ordered an adapter so I can test the coil on plug's secondary ignition waveform(s). Where should I go from here? Many thanks, Adam
The following user(s) said Thank You: Batiscafo
3 years 7 months ago #42530
by Batiscafo
Replied by Batiscafo on topic Re:2002 MR2 Roadster. 1ZZ-FE, misfire and low idle when hot.
HI, are you still using the Hatek 1008C?
I had bought one last year and returned because I could not leave with all errors of the software (at least in my opinion which has very little experience).
It seems they discontinued a while ago. I returned and purchased the Pico 2 channels but I may have fried it, so maybe i need to reconsider.
How do you manage with the 1008C?
Time to create page: 0.205 seconds
