2002 MR2 Roadster. 1ZZ-FE, misfire and low idle when hot.
- kamiwolf0893
- Topic Author
- Thank you received: 2
Nissan Technician
kamiwolf0893 wrote: The precats look like one main cat from a glance but with the heat shield removed, each bank has its own precat. There's a main catalyst further down
Good to know! My mistake.
- kamiwolf0893
- Topic Author
A scope would've been nice. Makes life a lot easier. Good investment if you ask me.
Just to be clear you've done all your testing when the engine runs rough or misfires right? I assume there are no misfire counters in your datalist. PIDS are probably limited.
So I lifted them off the spark plug one by one, theyre all firing.
Did your engine rpm change on all cylinders when lifting the coils?
- kamiwolf0893
- Topic Author
- kamiwolf0893
- Topic Author
Anyways. Let's make a list to keep track here.
*good spark (still needs to be verified)
*fuel pressure
*compression
*intake vacuum
*no backpressure
*O2 operation and working cat
*ECT, MAF, IAT...
*Injectors
*Mechanical timing
*Vacuum leaks
*EVAP
*PCV
You've gone through all this right? Quite a lot Feel bad for you man.
Is your scan tool bidirectional? If so perform an actuator test for the VVT. I'd like to know if it stalls. You can also unplug your OCV see what it does. Normally nothing. I've seen maybe 1 of these engines that throw a P1349 and eventually changed the valve or cam phaser. These can stick. But don't change anything so far.
kamiwolf0893 wrote: Also, do you have a link for an affordable scope? Probably only gonna use it on occasion if I do get one. Can see why you say it's a useful tool
You can check out our diagnostic tool section on the forum. Lots of info. I hear a lot of positive feedback on the Uscope. It's only 1 channel but very handy.
- kamiwolf0893
- Topic Author
- kamiwolf0893
- Topic Author
I would be careful with changing parts that are not original or Chinese crap. You could be chasing your tail.
OCV is the oil control valve that regulates the oil flow to the cam phaser on the intake.
- kamiwolf0893
- Topic Author
- kamiwolf0893
- Topic Author
- kamiwolf0893
- Topic Author
- kamiwolf0893
- Topic Author
