[FIXED] 1998 jeep grand cherokee no start
- bill.rabadue
- Topic Author
4 years 4 months ago #35679
by bill.rabadue
1998 jeep grand cherokee no start was created by bill.rabadue
I'm new here. I love the videos that you have been posting. I need some help with a 1998 jeep grand Cherokee. I bought it off a buddy of mine to use as a trail rig. It sat parked in a garage for a few years before he sold it to me. It started up fine and we loaded it up on a trailer and I brought it home, when I went to pull it off the trailer it started then stalled now it will not start at all. I have no codes I do have spark the engine light is on and the fuel pressure is 45psi. I found the video of you testing for a 5 volt reference. So I tested the TPS for 5 volt what I found was that I have two wires with 5 volts. ( the wire is unplugged from the TPS) I know that I should have a 5 volt reference wire, ground and a signal wire. Any help would be greatly appreciated.
4 years 4 months ago #35680
by Cheryl
Replied by Cheryl on topic 1998 jeep grand cherokee no start
That’s normal to have 5 volts on 2 wires unplugged. It’s a pull down sensor sounds like. Are the injectors firing?? They might be stuck closed from sitting for a few years.
The following user(s) said Thank You: John Curtis
- bill.rabadue
- Topic Author
4 years 4 months ago #35690
by bill.rabadue
Replied by bill.rabadue on topic 1998 jeep grand cherokee no start
Not sure if they are. I do not see a change in the fuel pressure when I try to start it.
- John Curtis
- Thank you received: 109
4 years 4 months ago #35694
by John Curtis
Replied by John Curtis on topic 1998 jeep grand cherokee no start
Cheryl hit the nail on the head. However, if it isn’t gummed up injectors and you are getting spark, I would check for injector pulse. If you’re getting injector pulse, adequate fuel pressure, and spark, you need to see if the injectors are actually spraying and atomizing the fuel properly. Fuel quality should be a concern as well.
The following user(s) said Thank You: bill.rabadue
- bill.rabadue
- Topic Author
4 years 3 months ago #36203
by bill.rabadue
I would like to thank all for the help with my Jeep. I got it up and running today. Found that the spark plugs were bad. Tested for spark at the spark plugs wire not thinking to check at the plug but no matter got it running. Thank you for all your help.
Time to create page: 0.216 seconds
