p1698 2000 dodge dakota sport 4x4 with a 318 v8
- jetter3606
- Topic Author
- Thank you received: 12
4 years 4 months ago #34940
by jetter3606
Replied by jetter3606 on topic p1698 2000 dodge dakota sport 4x4 with a 318 v8
the key is black
4 years 4 months ago #34941
by Cheryl
Replied by Cheryl on topic p1698 2000 dodge dakota sport 4x4 with a 318 v8
Check powers and grounds at pcm and call it
- Thank you received: 140
4 years 4 months ago #34953
by VegasJAK
Replied by VegasJAK on topic p1698 2000 dodge dakota sport 4x4 with a 318 v8
readings at the DLC should be 2.45 for pin#3 and 2.47 for pin#11. all others do not matter at this point... the bias voltage comes from the BCM. A reading of 2.5 not correct.
Your problem is communication between the PCM and TCM. The test of pins 3 and 11 are telling you their is a short between the vio/brn wire and the wht/blk wire between the PCM and TCM.
Set you DVOM to 20 in DC volts. That should give you 0.00 scale.
- jetter3606
- Topic Author
4 years 4 months ago #34962
by jetter3606
got batteries for my other DVOM and read correct voltage out of the datalink terminal at 2.45 on 3, and 2.47 on 11. as I went to pull pcm from truck, I noticed a considerable amount of oil coming out of the right side bulk connector , im guessing the oil sending unit goes to this connector and has failed causing oil to get into the pcm
- jetter3606
- Topic Author
4 years 4 months ago #34993
by jetter3606
Oil sending unit was dry ,, Power steering pressure switch was the culprit . pulled the connector and it was soaked with fluid, I started the truck and the engine light went out. but came back on and the gear indicator lights stayed on. i guess this fluid migration isnt an uncommon problem for D. according to a D. forum .. i think the pcm is bad still I cleaned the connector good and It may need a wiring harness too .
4 years 4 months ago #34994
by Cheryl
I’m confused. So it’s sounds like the 5 volt reference was shorted.
4 years 4 months ago #34995
by Cheryl
So was it a no communication with the pcm at any point with a scanner??
- jetter3606
- Topic Author
4 years 3 months ago #35645
by jetter3606
I got a new PCM and still .P1698. There is no signal to trans relay when checking with test light and the relay pulled, cycling the key . im tearing apart wiring harness now and not finding much so far I have 2.46 and 2.49 on the twisted pair wires .out of tcm and pcm and at data connector under dash what color wire sends signal to the trans relay in the fuse box does anyone have a diagram that shows what wires to look for ? I pulled apart the fuse box and looked at underside it all seems pinned correctly any info and diagrams would help thanks
4 years 3 months ago #35669
by jreardon
Replied by jreardon on topic p1698 2000 dodge dakota sport 4x4 with a 318 v8
- Otbrecords
- Thank you received: 13
4 years 3 months ago #35675
by Otbrecords
Replied by Otbrecords on topic p1698 2000 dodge dakota sport 4x4 with a 318 v8
Cheryl, I kinda skimmed through the conversation posted so far and forgive me if I'm wrong or you've already addressed this. It sounds like a 5-volt reference short. We're sensors unplugged one by one monitoring for a correction in voltage? Also have you tried unplugging the battery for a while making sure voltage is drained out of system to reset/ deactivate limp mode. If it is some sort of limp mode maybe that would correct it. Just a thought.
Time to create page: 0.228 seconds
