2008 driveability issues
4 years 7 months ago #33154
by ed begley
Replied by ed begley on topic Re:2008 driveability issues
so i decided to redo the coil tests, i dont if i did it wrong the first time , if i just missed it but when i checked the chassis ground it ws open .when i saw this i used a jumper wire from ground to the t pin i was using, I. started the truck and all 4 cylinders on the drivers side were working I could not locate the open in the wire so i ran a new ground wire. At this time all my stft and ltft numbers are line with the pass side . I am mad at myself that i did not follow the basics , i was sure that it had to be computer related thats on me, no matter how advanced the computer stuff gets things still need gas spark air and compression. I would like to thank everyone for their help and obsevations, and a special thanks to scannerdanner for providing this forum
thank you everyone
thank you everyone
The following user(s) said Thank You: simclardy
4 years 7 months ago #33168
by Andy_
Replied by Andy_ on topic Re:2008 driveability issues
I'm sorry that I lost track of this, for some reason I wasn't getting updates that there were new messages.
I'm glad you found the problem, good work.
4 years 7 months ago #33179
by simclardy
Replied by simclardy on topic Re:2008 driveability issues
You got it fixed. That's what counts. Cheers
Sent from my SM-G930V using Tapatalk
4 years 7 months ago #33425
by Raoul
Replied by Raoul on topic 2008 driveability issues
I think at a minimum your fuel pump is no longer achieving an adequate fuel pressure at Prime. AlldataDIY would be a good investment as the FP Specs will be published there. Running out of fuel on an older GM FP often stresses out the tired Unit. The erratic needle on your fuel pressure gauge is a typical symptom too. So FP and fuel filter to start with. The misfire May be a bad injector (one cylinder) or fuel regulator if multiple cylinders (P0300). However, try the FP and filter first. Longer crank times to start too (another FP symptom)? Cycle your key a couple times before starting and see if crank times is decreased!
Time to create page: 0.229 seconds
