2008 driveability issues
aditionally this problem seems to affect the whole left bank , i would think it would be pretty unlikey that all injectors on just the left side.
i pulled all plugs , all plugs on left side are snow white lean , performed a compression test all cylinders 150 160 psi
so at this point i know mechanically the eng is ok
i cant help but think that i must have a massive vacuum leak that is only affecting the left bank ,
i will trying a smoke test in the next day or so, but i am not sure where to attach smke machine to eng , i dont not have avacuum brake booster so i can not attach there.
I was thinking about tapping a fitting in the snorkel, and then capping it when im done. Also if i hook up through the snorkel will smoke be able to get past the closed throttle plate
i look foward to your volume test
thanks
Sent from my SM-G930V using Tapatalk
I just skimmed the responses, so I apologize if I say something that someone else did or that I missed. What scan tool are you using? Are you able to record data on a test drive? You can probably pick out your problem by selecting the correct data and analyzing it. If you can record data let me know and I'll tell you what PIDs to record.
As i said i will check if the scanner i have has recording capabilities
thanks ed
i did figure out where i can hook up a vac gauge i am getting 16 inches at idle, which i suppose it is not to bad considering it is running so poorly
it is still baffeling that 1 bank is so lean
i did swap injectors from side that is running poorly to the side that is operating properly, so i know that clogged injectors is not an issue
i dont have a problem doing a road test and recording data , but shouldnt i be able to see changes at idle, i can see data that suggests that it is running lean and trying to add fuel even at idle
any help is appreciated thanks ed
On the vacuum gauge is the needle steady? When you snap the throttle what is the low and high numbers? At steady high rpms what is vacuum and is it steady?
I agree that something common to the bad bank is the culprit. A breathing problem on one side, a bad ground that is common to say injectors on one side, a pcm on one side.
Look forward to you finding the solution, and the path that leads you to it. Cheers
Sandy
i look foward to seeing what PIDs Andy wants me to monitor
would i introduce propane through the intake before the maf sensor by removing air box lid
like i said i may not be able to get back to untll friday due to my work schedule
thanks for your help
thanks ed
Since all cylinders are not firing on bank 1 (confirmed with spark tester works on bank 2 not working on bank 1).I found something on line on how to test gm cop coils, i performed this test at the main coil harness not esch individual coil ,
pink wire should be 10-12volts......12v ok
black wire ground should be 10-12volts.......12v ok
brown wire low refrence signal...........should be 10-12 volts ...12v ok
green wire trigger wire should read 5-8 hertz i got no reading on this wire
thqt being said i checked continuity between pcm and this grn wire , wire actually changed color to red/wht in harness it went to #20 in pcm connector 1 and i had continuity.
At this time i assumed that i had an issue with the pcm
I thought where does the grn wire on bank 2 go so i checked continuity from there expecting it to possible go to connector 2 however it actually had coninuity to the same terminal #20 connector 1 as bank 1 , i tried the same test on on the grn wire looking for 5-8 hertz again i got no such reading . I thought what if a ran jumper from bank 2 grn wire to grn wire bank 1 maybe they bwould all start working, when i did this the eng just shook and misfired more.
at this time i thought what is swapped the entire coil assy all 4 from one side to the other , coils from bank 1 that were inop are now working properly and coils from bank 2 that were working are now inop.
I am a little confused sine both grn wire go to the same terminal at the pcm connector, i dont know if there is another way to determine the trigger signal other than a hertz reading as this test was inconclusive
the chart that i found for pcm breakout ..says battery positive voltage
i was unable to read any voltage at this terminal grn wire at either bank yet bank 2 is working
even tried a cop coil tester ( looks like a mini fly swater) you just hold it on coil and it will light up on a working coil lights up on bank 2 not on bank 1
i would be happy to try any other tests or if anyone ahs a link to wiring harnes diagrams
what i dont understand is why the bank 1 and 2 seem to have the same readings
the instructions called for a reading in hertz on the trigger wire , i did not get a good reading on this circuit which is why i still have a problem,
what also dont understand is that the grm/wht wire on the bank 2 and the grn wire on bank 1 have continuty to the same pin on the pcm connector, on top of that when i check continuity from grn/wht to grn wire Using the (beep function) i get no beep but i do get resistance reading of 1875 ohms
i know i am close but i am missing something on bank 1
here is the link to cop diagnostics
easyautodiagnostics.com/gm/4.8L-5.3L-6.0...test-the-cop-coils-2
As for the hz test. What kind of meter do you have? Try it in a wall outlet if you feel comfortable doing so and you should get 60hz. Make sure the meter can go down to 5hz. Some meters don't have the range.
A wiring diagram would answer the question on the signal wire being shared. An ohm test to signal just measures the component resistance, and i don't think it's helpful.
I would expect each coil to have a dedicated signal wire? Unless it is some type of data cable. Doubt it.
Your are almost at the end!
