2005 Ford Taurus SEL (DOHC) 4-wheel ABS?
4 years 8 months ago #32468
Replied by Tyler on topic 2005 Ford Taurus SEL (DOHC) 4-wheel ABS?
Sounds like it doesn't have a sway bar. You're seeing the two lateral arms and the trailing arm.
If it had a bar, it'd be located inboard of the strut. Like this, but not blue:
www.taurusclub.com/forum/attachments/sus...ll-passsidelift2.jpg
4 years 8 months ago #32502
by popoften
Replied by popoften on topic 2005 Ford Taurus SEL (DOHC) 4-wheel ABS?
Will either a propane torch or mapp gas torch provide sufficient heat? I do not have oxy-acetylene. And I assume I would apply the heat to the pinch apparatus and not the bolt; since the thing heated is what expands?
Thx Pop
Thx Pop
4 years 8 months ago #32503
Either one can definitely help! It's a mixed bag with those - some are super crusty and just fall out. :lol: Others look clean and fight the whole way.
You'll figure out pretty quickly which one it is when you go to loosen them by hand the first time.
4 years 7 months ago #33165
by popoften
Replied by popoften on topic [FIXED] 2005 Ford Taurus SEL (DOHC) 4-wheel ABS?
Finally got around to this job over the weekend. It wasn't too bad. But you were correct that the pinch bolts needed heat and penetrating oil, and fought hard a good bit of the way out. And were very clean on this garage-kept, southern car. Noise gone, rides real nice now. THANK YOU!
4 years 7 months ago #33166
by popoften
Marked FIXED.
Thank you one and all.
4 years 7 months ago #33202
Replied by Tyler on topic [FIXED] 2005 Ford Taurus SEL (DOHC) 4-wheel ABS?
Nicely done.
I hate the whole pinch bolt strut design. Always a pain to remove, and no easy camber adjustment. It's like the OEM doesn't care what happens to the alignment once it leaves the factory? Oh yeah, they don't! :silly:
Time to create page: 0.207 seconds
