[FIXED] 2001 ACURA CL 3.2 CRANKS/ NO START
- tim.smith1
- Topic Author
- Thank you received: 61
- tim.smith1
- Topic Author
- tim.smith1
- Topic Author
so the 500mV in the graph means it was hitting around 5 amps.
- tim.smith1
- Topic Author
- tim.smith1
- Topic Author
- tim.smith1
- Topic Author
tim.smith1 wrote: 2nd channel is on number 4 coil Control wire Brown in color. Most likely the plugs are wet. When I check fire on coils they are firing bright blue.
Hold a plug up, with an air gap to ground, and take a current ramp on just that one coil. I want to know if the turn on oscillations are supposed to be present on these coils. I'm genuinely curious now.
tim.smith1 wrote: So scope is loosing internet took picks with phone amp clamp on 1mv/10ma should see green trace on scope for settings
Did you type that correctly? 1mv /10ma ?
Can you test that brown wire again, plugged in and unplugged? That signal did not look right, although it did trigger the coil.
- tim.smith1
- Topic Author
- tim.smith1
- Topic Author
tim.smith1 wrote: this is a amp off battery and injector an coil off number 3 cylinder i hope it shows up. if i can improve image somehow please let me know
Someone please correct me if I'm wrong but shouldn't injection be taking place during intake stroke? Why is injection taking place within spark dwell time, which would be around compression stroke?
- tim.smith1
- Topic Author
- tim.smith1
- Topic Author
