P0171
4 years 11 months ago #29702
by jscordo
i was thinking same thing, i spent 5 hours back there replacing exhaust manifold gasket after i couldnt find a crack in manifold. the 02 sensors are reading as they should with the upstream oscillating back and forth and the downstream staying steady above .50.
ive had a manifold leak before and the downstream would ready similar to upstream
4 years 11 months ago #29711
by guafa
It was the purge valve. I was not clear. Not for this particular car, but for others.
You can discard evap system, by "canceling" the hose which is connected to manifold
I have some known good values for that ecotec 2.4L taken two days ago. Maybe not only watching trim numbers, but more values, we can discover something else.
4 years 11 months ago #29719
by jscordo
i'll try anything at this point. i'm going get a new coolant temp sensor just to be safe and because its cheap. i just cant wrap my head around the two different readings from the two different year fuel rails. 2010 injectors have a different part number compared to 2012 and the 2012 injectors work way better. i might do the high pressure pump down the road. someone said that could be it
Time to create page: 0.233 seconds
