89 Chevy Silverado issues.
Someday I'll figure this out
Im going to get a new sensor tommorow and see if that fixes it. the sensor should not have a hot melt spot on it, and I dont think the voltage should be fluctuating that fast or that much. probably 5 different values a second. like a confused calculator.
so I dont want to mess with my other truck and something fail, just as I happened to pull it off, then im out there really sweating it, because that is my fishing truck.
If I could find a vid on how exactly the gm computer sequence of operation works, I would get alot out of it. I understand the gm bypass ignition system, its the fuel mapping I would like to know intimately. like what EXACTLY is happening when its surging, is the map reference sensor out of tolerance and the computers sees this and tries to default the fuel trims back to a preset parameter or does it just ingore the errant signal and depend on the coolant temp sensor, and or tps signal.. basically what is going on in the ecm.
Also, I’m not positive, but I think the voltage swing max to min should only be about 1.5v on these map’s. If you had something like a mityvac hand pump to apply a steady 19 or 20” of vac, you could remove the variable of fluctuating engine vac. For future reference.
what would be expected for an old truck.
we have replaced battery, ignition switch, radiator, water pump, belt , pulleys, fan, hoses , t stat, brakes and hardware, differential fluid, topped of transfer case fluid, replaced worn sway arm bushings in front, had heads decked and valves worked, complete top end gasket set, new o2 sensor, new tps sensor coming, new cap and rotor, ingnition module replaced and distributor refubished, fuel filter removed and cleaned. new washable air filter. the only thing it needs left to pass inspection is the exhaust pipe needs to be extended to the outside of the bumper. all 4 headlights and tailight lenses were replaced before we got the truck. wish he had replaced the casette player,, haha
yes he has a little honda civic my bro in law gave him, but every man needs a truck. he could go pick dates up in it. some chicks like old trucks, that raw rumble , smell of burnt oil, they are roomy and manly trucks. that bench seat is good for hugging too. she caint be too fat though, if she is blocking the stick shift, you have to ride around in one gear. My wifes always trying to make excuses to drive my 94.. I tell her she cant handle the silverado,,, too much power. I keep my boat hooked to my 94. If I unhook it and bring it in the front, she will hop in that son of a gone and go. Like its a strong . loud wild horse shes wanting to ride ha it is loud dual exhaust, and puff a plume of smoke on start up, (lworn valve stem seals). love to see people reaction when at gas station and they are behind me, the hear VRROOOO, then the bluish black cloud drifts over thier car,, ha
My 94 runs super, and shifts like dream .
Im thinking that some of the reason for changes in the way the truck runs may be due to when the truck is shut off, the computer resets to a base parameter, and then starts trying to compensate to a happy spot, or in my case compensate for a faulty sensor and incorrect voltage signal .
anyway kif u ever go to get a transmission rebuilt, ask them whats the most important aspect of a transmission, if they dont say hydraulic pressure integrity,, RUN..
This truck has grabbed hold of me like a pit bull on a chihuahua. It simply refuses to leave me alone, like its been neglected so long, and it has somebody who is trying to fix it right, and it has attached itself to me, like a barnacle.
Its like every time I fix something, another issue pops up, like the truck has a gig list its feeding me.
the truck isnt throwing the code 43 right away, as I understand it does a test on every start cycle. I erased codes, ran it for abt a minute then rechecked for codes, it was clear. then I started it again and let it run. it seems like the idle surging got progressively worse. I read that the computer will keep either retarding or advancing the timing in 1 degree increments to attempt and cause an engine knock. so im thinking this could be the issue. I can take pics of the sensors in speaking of if needed. it looks like the wire going to the sensor on the opposite side of the block, was spliced in. it is seems it was done by someone who at least knows what shrink tubing is. so folks, it seems we have another scooby do mystery to solve. as I said my oil pressure sensor is near the oil filter, not near the distributor as many seem to be. the sensor in the block had to be for something but there is no wire that goes to it, or a wire nearby that isnt plugged in,, the sensor in the opposite side of the block from the sensor in front of the starter looks a bit different., it does have a large black rubber connector plug on it,.
attached is the part im speaking of. possibly the circuitry in it is different, I didnt pay attention to what year truck it came off of.
I tell ya I will never by a truck again where half the engine and electronics are missing and the other half have been installed in the wrong locations.
this is getting ridiculous,, the only reason I think there would be a second knock sensor is maybe they couldnt get the original one out, and removed a block drain, installed it on the other side, and spliced an extension wire to reach. they are only supposed to be torrqued to 14 ft pounds,. shouldnt be stuck in there.
