Re:Re:diy repair blunders
5 years 9 months ago #21955
Replied by Tyler on topic Re:diy repair blunders
:lol: They should have put that on the brake fluid reservoir. MUCH more expensive repair that way.
- Thank you received: 958
5 years 9 months ago #21962
Replied by Noah on topic Re:diy repair blunders
This is from a Nissan Murano ( no, not that Murano )
that had 3 different size 18" tires on it. I kind of suspect that had something to do with the torturous death this differential must have suffered...
- Matts Auto
- Thank you received: 28
4 years 6 months ago #34185
by Matts Auto
Replied by Matts Auto on topic Re:diy repair blunders
3 years 6 months ago #43382
by Tutti57
Replied by Tutti57 on topic Re:Re:diy repair blunders
Customer - I found a fuse blown so I replaced it. That one blew, so I went up a number (original was 5a). That one blew too so I put a 30a in and it fixed it for a little bit then I smelled burning.
Welp, I put a dash harness in his Altima today. Expensive lesson. It's hard to tell where the original short was since there was so much damage but one spot has some corrosion, so I think that was the spot.
Those are the other blown fuses I found and I felt good only having those two screws left over!
Nissan Technician
Nissan Technician
3 years 6 months ago #43398
Replied by Tyler on topic Re:Re:diy repair blunders
Mercedes GL350 gets towed in. Front end is on the bump stops, air ride problems. Right front wheel is held on by two bolts. The hub (once removed from the bearing) looks like this:
It appears that something went wrong with the threads? :huh: I dunno the story. It came in with a couple Helicoils got installed. Then, they somehow broke a wheel bolt off in the new Helicoil. :lol: :lol: :lol: I guess that's when they called the tow truck.
Time to create page: 0.216 seconds
