Re:Re:diy repair blunders
The things that drew me to Paul's videos was not only that he taught great troubleshooting techniques but that he is not afraid to say 'I don't know.' and then look for answers. Also, if he goofs he admits it and then fixes the problem.
Exactly! And that is very rare these days...
As soon as the coughing and sputtering started, I had a flashback of turning the crank after the first side was done. :facepalm:
- Thank you received: 959
OH, that SUCKS! Thanks for using your first post to share that with us, and welcome to the forum!PDM wrote: My first real experience with DOHC was doing a timing set on my Cobra. Managed to get the right bank 180* out :silly:
Sucked for sure! Have to jack the motor up on those cars just to get the valve covers off. Pulling the timing cover is an ordeal!
PDM wrote: Thanks. I was on the old forum a little while.
Nice, an OG member. Love to see people returning from the first forum version.
Your DOHC Cobra talk is giving me anxiety! I've got a '97 in the shop I'm putting a small block in - pretty darn sure I got the timing right, but the OE timing procedure is super vague.
- Thank you received: 1031
We have been there...... these days I use lot of paint marks and take pictures with my phone even on engine types I know well,
Back in the old days with 2 valve per cylinder twin over head cam engines it was even more worrying, when you have two big valves because the valves were so much bigger and the cam needed more lift add the fact in those days the valves were set at 90 degrees to each and get it slightly wrong and the valves either crash into other or the piston. Jag XK engines weren't too bad because on pre-XJ6 models they supplied the required special tools with the car but Lotus-Ford Twincam engines were a pain to get right.
Modern 4 valve per cylinder engines usually have the valves set at about 40 to 45 degrees to each other and the camshafts have only half the valve lift so although they are still interference engines you are more likely to get away with small mistakes without bending valves.
Hitting it with a Hammer is worth $5 knowing where to hit is worth $40
That's a LOT of work to do in your drive way. The u bolts alone would give most DIY'ers a run for their money with no air or heat. Let alone making 16 perfect cuts through spring steel!
I'm gonna be laying under Explorers in the grocery store parking lot looking for one like that!
Had a Dodge come in that had just been to Stealership
Stealership :woohoo: :lol: :lol: That's a good one.
Yeah this is definitely a mistake you don't wanna make too often
about A/C repair made me think of something I saw an old man do many years ago.
There was an old Lincoln Town Car limousine that I'm presuming had some kind of A/C performance complaint.
The old timer says that she needs a "deep reduction". I didn't see his connections, but I saw the giant, stinking smog cloud make the building disappear when he figured out how to hook a service port up to intake vacuum and hold it at 3000 RPM.
I found one!Ephratah wrote: had a old explorer come in and some one decided they did not need 5 leafs in the rear and cut the other 4 off and left them for spacer blocks. This is a new one for me and makes you ask what were they thinking?
- shepherdguy
JeffBirt wrote: To be fair I have seen some 'professional' mechanics do some really stupid things too......I put 'professional' in quotes as my Dad used to say that 'professional' only meant you got paid to do something not that you were any good at it.
I like to say, "Do they really have 25 years of experience or do they have 1 year of experience that they've held for 25 years?"
Anybody have the torque specs for the sheet rock screws that hold the convertible top to the windshield frame for an 01 Sunfire? Don't want this girl to leak...
