Re:Re:Show us your homemade Test Equipment
- Wightscope
- Topic Author
- Thank you received: 29
A cheap 433 receiver from ebay is next stop , but I do like to re-purpose OEM kit !
- Wightscope
- Topic Author
- John Curtis
- Thank you received: 109
- Thank you received: 958
Those look great!John Curtis wrote: I’ve got a whole list of things to develop and make. So far this is it.
- John Curtis
Thanks. Just tuned everything in and fixed the flaws going forward that were in the initial sets. The initial sets are functional but a tiny bit out of square during production. Figured I’d make a holder for them that can double as a way to hold my test leads.
Unfortunately I’ve got about 4 sensors that aren’t perfect visually but have the same functionality.
Unfortunately I’ve got about 4 sensors that aren’t perfect visually but have the same functionality.[/quote]
PM sent
- John Curtis
AJeep18 wrote: [quote=
PM sent[/quote]
Responded.
- John Curtis
John Curtis wrote: I’ll PM you.
No I'll PM YOU!
- Wightscope
- Topic Author
I have been using stackable banana plugs - effectively both male and female so one on the test light one on the earth clamp and all my probes also fit so I can alligator or probe for a jumper.
Also got a 10ft double ended retractable reel that has two wires, one I put stackable bananas on each end, others are alligators.
Just made a cable today for using a phone power bank as a 5v power supply for pressure transducers, added 33ohms of resistance else the powerbank shuts off after 30s. Sadly 150ma was too much for the LED I built in to it!
Wightscope wrote: Just made a cable today for using a phone power bank as a 5v power supply for pressure transducers, added 33ohms of resistance else the powerbank shuts off after 30s. Sadly 150ma was too much for the LED I built in to it!
Good thinking about the resistor. I've had problems with both a power bank and a 18V>12V/5V power tool battery adapter shutting down at low load with my USB>Banana cable. The tool battery adapter was also shutting off the 12V with my 10-30V "transducers". Hacked it to to run 18V straight from the battery to the 12V port.
- Wightscope
- Topic Author
Mainly use it via a 12/24v buck to run a Quiko soldering iron set up - that works really well -and I have a Jump starter handy as a bonus.
Most of my transducers are 5v but I just got a 10Bar absolute (ie complete vacuum to +9bar) sensor that is 12v, - going to need a load cable for that too.
AJeep18 wrote: Beat you to it Tyler
Lookin' good.
- Wightscope
- Topic Author
So at 1200rpm a sound at 10Hz is going to be valvetrain as the cams rotate at half the speed of the crankshaft, or maybe an idler pulley bearing - if it is 2/3rds of the size of the crank pulley will make a noise at 13.3Hz
There must be a simple way of detecting which wheel bearing it is by seeing if the frequency goes up or down when turning a corner...
