Using a Piezo sensor to identify a noisey valve.
- Thank you received: 619
3 years 2 months ago #46432
Lol! That makes about 5 of us, in total. I've been collaborating with others, as well as this thread. I just posted it to a diagnostic group on Facebook. We'll see what some of those guys think.
Replied by Chad on topic Using a Piezo sensor to identify a noisey valve.
Wightscope wrote: I don't have a clue what's making the noise!
- Wightscope
- Thank you received: 29
3 years 2 months ago #46434
by Wightscope
Replied by Wightscope on topic Using a Piezo sensor to identify a noisey valve.
Just a thought, am I right in thinking this engine is chain driven with VVT ?
Wondering if there is a missing tooth or something in the VVT mechanism causing the noise?
You did mention it was missing a lot of oil and I assume it has hydraulic chain tensioners...
3 years 2 months ago #46435
by Matt T
You will. It's a private group :silly:
I think #2 intake valve can be ruled out. Noise appears to be happening before it opens. Don't see any way of telling which of the other 3 it is from the current waveforms though. Maybe a throttle snap or power braking would reveal a breathing problem??
Found this. Doesn't look like the noise could be caused by balance shaft or oil pump.
www.engineprofessional.com/TB/TB032816-1.pdf
BTW is this just for fun or are you still trying to diag it?
Replied by Matt T on topic Using a Piezo sensor to identify a noisey valve.
Chad wrote: We'll see what some of those guys think.
3 years 2 months ago #46436
Just for fun. :silly:
3 years 2 months ago #46467
It turned out to be #2 rod bearing (#2 and#3 are companion cyliinders). Sitting on the ground, I would have bet money that the noise was in the UPPER end. I would have lost. When I, finally, got it into a bay with a lift, It was clear that it was LOWER end. I pulled the oil pan:
and removed the oil pump.
Video
For those that are thinking it, I will go ahead and say it. Old-school methods would have diagnosed this in about 15 min, or less. But, I would not have had NEAR as much fun.?
Video
The following user(s) said Thank You: Wightscope
- Wightscope
3 years 2 months ago - 3 years 2 months ago #46470
by Wightscope
It was certainly interesting, and it was a good opportunity to brush up on in cylinder waveforms.
So the No1 low compression was a red herring - but still there.
What old school method would you have used for this other than perhaps a stethoscope might have nailed it bottom vs top then get the spanners out!
Last edit: 3 years 2 months ago by Wightscope.
2 years 7 months ago #51329
by SHIMHEAD
"Common sense ain't so common is it?"
Replied by SHIMHEAD on topic Using a Piezo sensor to identify a noisey valve.
With that much play in the rod lower end, that piston may have been contacting the cylinder head. A borescope inspection in the cylinder may have exposed a clue in the piston carbon deposits being "modified" by the contact.
