DIY Pressure Transducer
This what I bought
- bruce.oliver
- Thank you received: 88
Those are the same ones that I got. I've replaced my homemade transducer with a WPS500 kit. Very happy with itSooknanan wrote: Pressure Transducer Sender Sensor... www.amazon.com/dp/B0748C27LN?ref=yo_pop_ma_swf
This what I bought
Your waveform had the same issues as mine.
So I tried a 0-100psi on running compression to compare to the 0-300 and it was similar.
After some filtering with the 0-300psi I got this. I will settle with this for now since the waveform is still readable.
store.snapon.com/Pressure-Transducers-Ki...500-PSI-P636904.aspx
and could we use one of these to use multiple tranducers at one time:?
store.snapon.com/Pressure-Transducers-Ki...Adaptor-P637559.aspx
store.snapon.com/Pressure-Transducers-Ki...-Ultra--P737766.aspx
Description
• Adapts standard meter jacks to EEPV302AL, EEPV302AT and EEPV302AH pressure transducers (not included)
• Provides connection of transducer plug to standard meter jacks, and provides power to the pressure transducers
• Use up to two transducers simultaneously
• View results on VERDICT®/MODIS® Ultra/MODIS® Edge/VANTAGE® Ultra/M2 Meter
I am too cheap to buy one LOL Will have to sourse everything. see attached image
- Jose santos
