Secondary ignition Pickup that doesn't cost an arm and a leg
6 years 1 month ago #17446
by SailorBob
I've gotten really crappy results with the Hantek HT25 secondary pickup, as can be seen here:
www.scannerdanner.com/forum/post-your-re...n-a-distributor.html
and I was wondering if someone would recommend a decent one which doesn't cost an arm and a leg?
- eric_generic
- Thank you received: 9
6 years 1 month ago - 6 years 1 month ago #17475
by eric_generic
Replied by eric_generic on topic Secondary ignition Pickup that doesn't cost an arm and a leg
I found a website:
autoscope.eu/products/
and they have probes for secondary ignition. Or
injectorservice.com.ua/equipment.php#0
same product and I think it is the main site because their forum is far more active compared to the first one. Lastly try contacting
probemaster.com/
Hope this help. Somehow. Cheers!
Last edit: 6 years 1 month ago by eric_generic.
6 years 1 month ago #17483
by arbez
Replied by arbez on topic Secondary ignition Pickup that doesn't cost an arm and a leg
The PicoScope ones are $58.00 (US). Which isn't bad, if you only need one.
www.picoauto.com/products/ignition-acces...-capacitive-with-bnc
www.aeswave.com/Secondary-Ignition-Pickup-MI074-p8756.html
www.saelig.com/product/PSA011.htm
You are sure it is your cable? My Hantek scope came with 4 of the Hantek cables that have always worked fine. I wonder if the quality has dropped off that much?
Anyone around you have a Pico that you could borrow a cable to test with?
A lot of the others look like they could be rebadged Hantek parts.
- Thank you received: 1031
6 years 1 month ago #17484
Replied by Andy.MacFadyen on topic Secondary ignition Pickup that doesn't cost an arm and a leg
With a distributor system primary and secondary will always be different as there is a spark gap between the rotor arm and cap , also if you a have a spark jumping to ground via a faulty cap.
6 years 1 month ago #17563
Replied by Tyler on topic Secondary ignition Pickup that doesn't cost an arm and a leg
I've gotten the most bang-for-the-buck with the AESwave Universal Secondary Test Lead set:
www.aeswave.com/Universal-Secondary-Test...-HEI-Dist-p9174.html
Works pretty darn well for distributor systems, coil-in-cap, and coil-near-plug systems. The paddle also works well, but only on a limited number of COP designs. This has less to do with the paddle, than with the coil design. In some cases, I've found that the paddle generates a better waveform on a secondary wire than the clamp does. :silly:
