Budget scope with long term recording?
- Desmond6004
- Topic Author
2 years 6 months ago #51803
by Desmond6004
Replied by Desmond6004 on topic Budget scope with long term recording?
My 10 year old tablet tells me I have 2 1/2 hours of recording time in automotive mode. I'm busy setting up a USB power supply in a case to keep it all going.
- Desmond6004
- Topic Author
2 years 6 months ago #51853
by Desmond6004
Monday morning and it's quiet at work which gave me some time to set it up. The data logger will come in useful
for long recordings monitoring charge rate or current draw. In the automotive module I can get about 2 1/2 hours
recording time but my voltage is stuck at 5v? I have to use the 10X function of the probe to keep it on
the scale and then it's not very accurate. How do you get a 12v scale?
- Desmond6004
- Topic Author
2 years 6 months ago #51855
by Desmond6004
Ok, I worked it out. use a 10X setting on the probe and then set probe to "10X" on the screen - duh!
Now I have up to 50v.
- Grouchyoldman
2 years 6 months ago - 2 years 6 months ago #51866
by Grouchyoldman
Replied by Grouchyoldman on topic Budget scope with long term recording?
I tried on my tablet to setup another power supply but it just kept drawing the power from the tablet. Let me know if you get it figured out because I could use it to.
Set your Rate up to get a better capture, THIS WILL LESSON THE RECORD LIMIT. Go to the app store and find hscope, scroll down a bit, it should ask some where if you want to become a beta test. Sign up, its free and he just released another new update today, which you won't get for a while if you are not.
Did you go into the probes and hit the cloud button? These are all for you if you want. Being able to program your custom probes and choose them off of a drop down, then displaying it in format you want is way cool.
Last edit: 2 years 6 months ago by Grouchyoldman. Reason: Added to content rather than opening another window.
- Desmond6004
- Topic Author
2 years 6 months ago #51869
by Desmond6004
With the red USB of the Hantek plugged into a phone charger and the other one plugged into my tablet it ran
most of yesterday morning and dropped to 25% after lunch set to record long term. When it isn't plugged into
the charger it drops 10% in a few minutes so I'd say the charger was supplying the Hantek when I had it connected.
I went through the probe downloads last night - looks like some useful stuff there
- Grouchyoldman
2 years 6 months ago #51871
by Grouchyoldman
I didn't get any cables with mine. Can you show me the cable? Is it the USBx1 port?
- Desmond6004
- Topic Author
2 years 6 months ago #51872
by Desmond6004
- Desmond6004
- Topic Author
2 years 6 months ago #51873
by Desmond6004
I see my uncle 'Ali' has the
cables for sale
- Desmond6004
- Topic Author
2 years 6 months ago #51906
by Desmond6004
This morning I plugged it into my 20 a/h 'brick' that I received yesterday and after it running for an hour
the tablet showed 73% and the brick was still at 100%.
I unplugged the scope and plugged the tablet directly into the brick and it took 1 1/4 hours to charge the tablet up
again to 100% [with it still switched on] and the brick showed 99%.
Time to create page: 0.207 seconds
