Will the Hantek 1008C show 4 spark traces at once?
- Thank you received: 1031
The 6022 software will also lack the scale for the ignition HT but that shouldn't be a problem.
If you buy 6022be from Amazon and don't like it a refund should be pretty easy.
If it doesn't work out Amazon is good about returning things.
- 1971rscamaro
- 1971rscamaro
- 1971rscamaro
You indicated you are in Canada, I live near Victoria BC. Thanks.
With coil on plug or wasted spark there isn't really any need to look at multiple secondary traces although you may often want to use another channel(s) for say an injector or cam or crank signals.
With old style distributor ignition looking at the secondary trace from the coil (king) lead and one individual cylinder at time for synch is the normal way of working.
The manual in my opinion is almost useless,
I got it to shoe the complete set of cylinder's sparks in one screen by using the two inductive Hi voltage/secondary ignition set up on 10,000 on Scope and the leads one in CH-1 as a trigger placed around cylinder number one in the spark plug wire to that cylinder. It is set up as the trigger.
The second Hi voltage probe (exactly same as on number one cylinder is HT-25) I set it around the Hi ignition wire from the Ignition coil to the distributor.
Get the proper and same time sweeping on the Hantek and you can get a full parade of spikes with the first one being number one and the other just follow the ignition order of that engine.
The HT-25 is about $18 in eBay or amazon.
Now I have several issues with the software, e,g, the recording so you can stop the motion and see in detail the problem with the firing voltage.
Anyone that can help with that?
it is a shame Hantek cannot spend the time to fix the software and the manual, excellent product if you can get it to run at all.
- 1971rscamaro
play.google.com/store/apps/details?id=com.martinloren.hscope
Supported hardware:
- HS10X (DIY Oscilloscope www.martinloren.com/hs10x-diy-oscilloscopes )
- Hantek 6022BE/BL
- SainSmart DDS120 / Rocktech BM102
- Voltcraft DSO2020
- ARMFLY AX-Pro
- Hantek PSO2020
- Hantek 1008
- Hantek iDSO1070 / Saluki MO1072
- Instrustar ISDS205A
- Owon VDS1022
- Loto OSC482
- Loto OSC802
1971rscamaro wrote: By the bnc connectors on my Hantek 6022BE is labled max input 35 volts.
With normal non-automotive labscopes when looking at injector or coil primary wave forms using an attenuator is needed to be sure you don't spike the input circuits of the scope. This especially true with common rail diesel injectors.
