Basic Diagnostic Tool Set
- Thank you received: 961
This one can easily be bent any direction and is surprisingly resistant to breakage even after repeated bending. It will break eventually, but that's what the lifetime guarantee is for.
You can look at it here,
shop.curienllc.com/
You can watch a video by the rustbelt mechanic on YouTube here as well,
It's one of his nifty tools of the week series. A little spendy but if you use it for graphing, etc then you should be good as they're claiming high speeds for the graphing/sampling on it.
Watch his review, check the Curien website out and decide for yourself and go from there.
There's also a nice breakout box in the video. Don't waste your money on the Matco backprobe set unless you anticipate breaking a probe and you see the Matco guy at least every 2-3 weeks as the backprobe set is just a knock off version of the tool aid SG 23500 set they sell on Amazon. Maybe one of the mods reading this could drop a link in my message or after and maybe somehow link it thru Paul's Amazon store as I don't know if he has it but if he can add it as a affiliate link then I think we can support him and the channel for the same price which is still less than the Matco versions.
In the video he also shows the test lead set similar to one sold by www.aeswave.com which I think Paul has a link to also. To sit in the video is meant to be sold with the Bluetooth multimeter. I have the kit from AES wave so I opted not to get the shit in the video.
Dtnel wrote: A little spendy but if you use it for graphing, etc then you should be good as they're claiming high speeds for the graphing/sampling on it.
That claim doesn't match the sawtooth waveform that was generated when he switched the lights on and off. Anything "high speed" would've produced a square wave. That sawtooth looked like an averaged reading transmitted about once per second, which is really slow. The bar graph on my Fluke DMMs updates 40 times per second IIRC.
I use it with my Powerbuilt ultra-lowprofile 3/8" sockets. These sockets go from 8mm to 18mm. A 3/8" drive 8mm socket is VERY nice to have when dealing with hose clamps. My power ratchet makes their removal instant. You need low profile sockets. They are specialty tools that can be hard to find. This is my exact set. Look for something similar. www.overstock.com/Home-Garden/Powerbuilt...5864381/product.html
At only $89, it is cheaper than Harbor Freight! You can pick it up at any Home Depot. The battery is serviceable after its end of life as it's only 3 18650 cells.
If you are just getting started and spending $90 on an excellent ratchet is too hard, this is a decent alternative: www.homedepot.com/p/Stanley-3-8-in-Drive...het-89-962/203740742 I had two of them stolen and I own a 3rd one now. It's the manual version of the ratchet I recommended above. This used to be my all-time favorite tool.
Another indispensable tool is the serpentine belt removal tool. It happens to also be a 3/8" drive anvil at the end of a long flat bar and a 1/2" drive anvil at the end of an adjustable 6" flat bar. If you don't have this, you will have a hard time reaching alternators. I use it a lot when working in confined spaces. Removing an alternator often makes the job accessing relevant sensors much easier. The best one of these is actually the rental from O'Reilly because it comes in a nice case. The cheapest would be from Harbor Freight. I use this thing on almost every car.
wiseleo wrote: You need low profile sockets. They are specialty tools that can be hard to find. This is my exact set. Look for something similar. www.overstock.com/Home-Garden/Powerbuilt...5864381/product.html
Just a question of curiosity... Why do I *need* low profile sockets? In 20 years, I've never been in a situation where I thought "I need a low profile socket". Honest question... Where would they be more useful than a regular socket?
- thatmechanicguy
- Thank you received: 5
You use low profile sockets so you can jump from one bolt to another real quickly and not have any 'rattle' btw the bolt/nut and socket when using an air impact wrench. I had the most expensive Snapon air impact ratchet, and if not careful, it would strip the ears off a bolt or round a nut (or break it off!).
The only time I reach for a long socket is when a bolt is sticking out too far past the nut or when I need more reach.
Cheers...
- WidowBalls
Does the book or course teach you how to diy to save $?
For DIY, that stuff if great. I use the vacuum gauge every day, no issues. The fuel pressure test kit has lots of adapters, it's a big kit but doesn't hold up to the daily grind in the shop. Atleast the one from 10 years ago didn't, they do make constant improvements....What are your thoughts on Harbor Freight for diagnostics equipment? Especially the compression, vaccum, and fuel gauge?
That said, I would definitely buy it for my home garage if I was in the market.
