Re:Re:Re:APT-100 Pressure Transducer
- Thank you received: 1420
Well it showed up yesterday! Without a battery.... so I jumped on Amazon to order a button less 18650 because my regular 18650s didn't fit (who knew there were different length 18650s....) anyway it theyvarrived today so straight to the charger it goes!
Ah yeah, it's like Juergen said with battery shipping. For anyone else considering an APT-100, I bought this set on Amazon:
www.amazon.com/dp/B06ZZ8Y89F
In the mean time I looked at the hose and decided it did in fact need drilled out so into the lath to get a nice centered drill hole and about 3/4 inch in the brass fitting broke off.... soooo time to replace the stupid coupler they come with and switch to automotive style..
:lol: Figures.
I'll let you know how that goes when I get there. BTW did you need any special fittings to connect air coupler?
I'll see if I can figure out which fitting I used... Stole it out of my oil pressure test set.
EDIT: Pretty sure that's a 3/8-18 NPT male to 1/8-27 NPT female fitting.
Haven't had a chance to use it yet, I did get it changed to some nice high flow connectors though. I've been working on a tailpipe adapter without much luck, im looking to do something like ATS tailpipe venturi but apparently that is harder to design without seeing the insides of 1 then I guessed because my test today was a fail
The tailpipe venturi from the E-Misfire kit? Never thought about trying to duplicate that. :huh: I was thinking about trying to do something like the Jarhead Diagnostics exhaust adapter for pressure pulse sensors:
www.jarheaddiag.com/shop/p/jarhead-diagnostics-exhaust-hose
The patents will help you copy it :lol: I've attached the first one. There are two more but they don't add much besides a screen for laminar flow.
Judging by the "prior art" Bernie had to invent this thing because he couldn't figure out how to use a piezo :lol: :silly: :lol:
I did make 1 of the spring hoses last year but I've never cared for the tailpipe pulse sensor with engine running
My piezo did a lot better sitting on the ground instead of hanging off the tailpipe. 1/4" brake line and 3/16" thinwall rubber tubing. IIRC Chad uses a mic stand for his
- Thank you received: 959
Cylinder #2?Matt digging up patent documents. :blink: :woohoo:
APT made quick work of a 5.7L Hemi with a suspected worn intake cam lobe. Misfiring cylinder in red, known good cylinder in blue/teal/whatever:
